Random ICE tip - compounds
Post by rray » 12 Sep 2014, 23:44
ICE sometimes acts up and compounds won't get evaluated anymore for no good reason (corruption?)
In that case what sometimes works quite nicely, instead of recreating/reconnecting the compound:
Switch the version 1 version back, and then:
Switch the version 1 version forward again :)
Not sure but in case there's no versioning on the compound, it might be possible to create a temp one from the defunct compound (?) and to do some switching
-ray
Re: Random ICE tip - compounds
Post by Bullit » 13 Sep 2014, 02:08
One node that happens is the rescale. Instead of inputing the values in the fields the user should connect to inputs an integer/scalar node with value.
Post by rray » 13 Sep 2014, 09:09
I don't have anything that can be reproduced. If you have a script log or steps that create this issue reliably with the rescale node, consider contacting support with it
Post by Bullit » 13 Sep 2014, 11:20
I mean it is something that randomly happens with rescale node.
