I have a grid.
I duplicate that grid (grid2) and move the points around.
Now i want with ICE to be able to move the points of grid2 to the positions of grid.
This should be possible since the amount of points is equal.
But i have problems retrieving the positions of the original in combination with knowing the ID.
Can someone help?
move pointPosition to original position
clankill3r
Re: move pointPosition to original position
Can't you just do
Get grid.PointPostion -> Switch Context -> Set self.PointPosition ?
clankill3r
thanks! It works.
Why can I use self.pointPosition and not self.pointPositionTarget?
I know pointPosition exists and pointPositionTarget does not but I would like to interpolate.
Pancho
Use self.pointPosition and otherMesh.pointPosition (with "switch context") and plug both into "linear interpolate" > set data (self.pointPosition")
clankill3r
THANKS, WHEN I TRY THINGS I ALWAYs get complex structures that don't work.
When you guys explain things it all seems so simple
