Hi Guys
I'm trying to link the scale of one object based on it's distance from another, so the closer it gets, a specified scaling value will take place, and the furthest it is from it, the scale will go back to normal.
Basically the effects im trying to achieve is like MAC OSX dock, where the mouse points the icons gets larger in scale, but instead of a dock, i have frames in a circular position (curve constrained), and every time i rotate the curve i want the center frame closest to the camera to scale in size, like a magnifying effect.
Any ideas how to achieve this in ice?
Thanks in advance
Regards
Scaling an object based on distance from another?
I3D
- Skype: ironic3d
Re: Scaling an object based on distance from another?
If you need to do this in ICE, you'd have to resort to the as of yet unsupported ICE Kinematics (or wait until SI2011 comes out for the supported (and hopefully much more stable) ones).
But you don't have to do it in ICE (as far as I can tell), you should be able to write an expression to achieve your goal...
Set an expression on the scaling (I'm not sure if you'd have to take the global or the local one) based on the ctr_dist function of the influenced objects multiplied by your scaling factor..
Or something like that
edit: sorry, I'm still sleeping
I3D
- Skype: ironic3d
Hi Hirazi
Thanks for the reply and the info, i did something like that previews to posting here, problem im having is how to control the range of scaling, meaning it doesn't go below 1, and it doesn't go more than 2? and maybe i just answered my self here
ok need to check the if statement
Rescale node - I think I have used it in every tree I've build. It's very useful node.
In this example I get distance between current object and some null and plug it into rescale node. Source start and end will be min/max distance when scaling takes place and target start/end - max/min scaling of object.
It's done on point level of course - you will need to wait for 2011 to do it on object level.
I3D
- Skype: ironic3d
Hi origin
Thanks allot, that did the trick alright, thanks again
