Syflex - control Volume growth per point?
I have an object that i want to inflate partially after being whole deflated, but i run into context issue since the Syflex volume inputs doesn't accept per point - in this case the weighmap - only per object. Any ideia how this can be accomplished?
Pooby
Re: Syflex - control Volume growth per point?
2 meshes with different syflex sims and mimic one to the other.
Thanks, but i am not sure following Pooby. Is the idea with mimic just partially follow the other balloon volume increase?
Pooby
Yes. It won't be accurate but it will allow for a level of mixing sims.
I see, thanks.
Pretty bad this mimic stuff. Not being able to make it work. Even the object moves for no reason.
Pooby
That's odd. I find it always works well.
Your mimic object doesn't jumps to the master?
Pooby
The points mimic the others points, yes. So it would jump if they weren't in the same place.
These are in same place.
Here is the simple scene if you can look at it. Just 3 boxes. Must be making some mistake.
