Particle density/transparency in the viewport
Pancho
Post by Pancho » 16 Jun 2014, 17:28
Can I change the transparency of the particles in the viewport? Actually I would like them to fade out over time. While this is possible for sure with the actual shader, I would like to preview the behavior in the viewport, so the particle color gets more transparent over time. Possible?
Thomas
Re: Particle density/transparency in the viewport
Post by Bullit » 17 Jun 2014, 02:48
For a speedy trick get particle color>multiply color by scalar>set particle color
Put alpha on and factor to 0.9 or more.
nixx
Post by nixx » 17 Jun 2014, 02:58
Or maybe even better,
separate the color channels using an rgba to color node, operate only on the alpha, then combine them back with a color to rgba. That way you won't mess with the actual color of the particles (if you 're using that in the shader).
You can save it as a quick compound named "modify particle alpha" or something, it often comes in handy.
Post by Bullit » 17 Jun 2014, 10:27
Separate with color to rgba isn't it?
It works but you need to define a timer or frame counter since all particles fade at same time.
Pancho
Post by Pancho » 17 Jun 2014, 11:43
Thanks!!! Works like charme!
nixx
Post by nixx » 17 Jun 2014, 15:42
Bullit wrote:Separate with color to rgba isn't it?
Yeah, I got the nodes backwards, it was the middle of the night :)
You could use a per-particle attribute, like age for example.
I 'm child, and man, and child again; the boy never gets older.
my Vimeo
Pancho
Post by Pancho » 17 Jun 2014, 16:03
That's what I did. Per particle.
Post by Bullit » 17 Jun 2014, 16:28
Yep forgot about that.
Edit: Pancho with my option you don't need that.
