Intersection Location?
probiner
Post by probiner » 25 May 2014, 13:21
Expectations: Get an array of intersection points between sphere and curve so I can constrain a Null to it. Boolean Location, or something?
Later one maybe te something between two meshes, but I guess that will be a lot of points...
Looked here: http://download.autodesk.com/global/docs/softimage2014/en_us/userguide/index.html?url=files/iceref_Get_Geometry_Sample.htm,topicNumber=d30e332031
Don't think any of those can help me. Any clues?
csaez
Skype: csaezmargotta
Re: Intersection Location?
Post by csaez » 25 May 2014, 20:01
Hi probiner,
What about a 'point in volume' node? you can get the intersections simply comparing the bool of each sample with its neighbors (if there's a switch then it's an intersection point).
probiner
Post by probiner » 31 May 2014, 09:53
Hey Cesar. Thanks for chiming in.
I have had thought of that approach but didn't tried to implement it since I was wondering if there was already a settled solution for this.
Had some strange issues with curve. VertexIndex shows a geometry output... Neighbors doesn't work, so I couldn't retrieve the data I've set like you pointed out to me.
Managed to get the closest location intersection with a 512 point curve. You can imagine that it twitches between the top and the bottom intersections when I move the curve. :P
