Really enjoy to use a combination of Rescale + FCurve + Linear Interpolate nodes. One sets the values for black and white limits. The other controls the gradient and the last one just turns that output into a mixer. Use it all the time!
The regret... Rescale and other nodes (though I notice more with rescale) get screwed up so easy at times and get reset! Why?
Say I delete a property map a rescale was being fed or I point to a wrong reference... Bam it goes to 0 1 0 1 ... Some exposed parameters disappear some times. So...
Had happen to lose some couple of hours of work because I saved a compound after a reference got deleted and rescale went reset.
My question is if I can avoid this and put fail safes to avoid this? What's really causing it? Invalid values?
Example:When the reference is corrected. Things show up again but with default values...0
