List comprehension FAIL ......anyone tell me why ?
Manticor
Post by Manticor » 15 May 2014, 13:49
Hi ,Im starting to use list comprehensions more in Python but for some reason I can't get this to work.
This code works
xsi= Application
lm = xsi.LogMessage
oSel = xsi.Selection
oRoot = xsi.ActiveSceneRoot
cluster = oSel(0).ActivePrimitive.Geometry.Clusters
for i in cluster:
	if i.type == 'sample':
		lm(i)
but this list comprehension version of the loop doesn't .... (Im assuming Im doing it right )
i = [ i for i in cluster if i.type == 'sample']
It returns this ------ > [<COMObject <unknown>>]
Can any Python gurus's here tell me why?
Im using XSI version 7.01
Manticor
Re: List comprehension FAIL ......anyone tell me why ?
Post by Manticor » 15 May 2014, 13:58
Sorry I figured it out.
its because it was passed into a list and I should have checked the properties of the item in the list not the list itself.
csaez
Skype: csaezmargotta
Post by csaez » 15 May 2014, 19:32
Hi there,
This is a stupid suggestion but here it goes anyway: i as a variable name is usually associated to an index (1, 2, 3...), so if you're looping through objects (properties in this case) try to use a descriptive name, like p or prop or whatever suit your needs.
List comprehensions are short enough and this should not be a problem at all, but naming things properly will save you many headaches in the future.
Cheers!
Manticor
Post by Manticor » 17 May 2014, 10:07
Ill bear that in mind for the future .I do this when Im iterating over a list as the container list describes what Im iterating over .But I do see your point .Thanks for the advice
Btw what software do you use for scripting ? Im using sublime but it doesn't have autocomplete for available methods for softimage keywords.And this is something that would save me quite a bit of time trawling through the sdk help files to see the available methods and properties.
I looked at degugging in pywin the other day and that has the softimage autocomplete but its black text on white which I dont like that for coding.I prefer light grey text on Dark grey.
Do you have any suggestions ?
csaez
Post by csaez » 17 May 2014, 19:38
I'm using sublime too.
Softimage SDK is all about dynamic dispatching and setup an autocomplete is not that straight forward. It's possible to inspect the sdk through win32com API but I've never tried it by myself (there are a couple of threads on the mailing list about this).
I use a couple of extra packages for python development (available through package control).
- SublimeCodeIntel to autocomplete python stuff (including my own code).
- SublimeLinter as a linter.
- Python PEP8 Autoformat to ensure PEP8 formatting on my code.
Cheers!
Manticor
Post by Manticor » 19 May 2014, 04:10
Nice one.cheers mate
