Change UV set to display in texture editor from python
Manticor
Post by Manticor » 06 May 2014, 14:07
Does anyone know how to change the uv projection to display in the texture editor from python ?
Im on XSI 7.01 btw
Any help much appreciated
csaez
Skype: csaezmargotta
Re: Change UV set to display in texture editor from python
Post by csaez » 07 May 2014, 04:48
There is a view attribute called "projection" to do just that, but is available starting from Softimage 2013 :(
Manticor
Post by Manticor » 07 May 2014, 05:51
I think I found another way to do it by selecting the projection and then opening the texture editor view.
You don't happen to know how to access the projections of an object using the object model do you?
I get as far as activeprimitive.geometry.clusters... After that I have to loop through the properties to get access to what I want.... I'd prefer to go direct without having to loop and filter.
Kenny
csaez
Post by csaez » 07 May 2014, 07:46
AFAIK that's the way to do it, you can always write a little function to keep things tight but yeah, that's the object model way.
get_uvs = lambda obj: [p for c in obj.ActivePrimitive.Geometry.Clusters
                       for p in c.Properties if p.Type == "uvspace"]
print get_uvs(Application.Selection(0))
Manticor
Post by Manticor » 07 May 2014, 09:03
I've written a function to get the object from any ".fullname" string .Seems to do the trick .
Thanks for your help cesar .
