porting ICE to VEX part 1
nikaragua86
Post by nikaragua86 » 06 May 2014, 07:13
yo, raps !!!
friends, take a look
How to port our precious ICE stuff into houdini vex. Questions raised - how to create a custom parameter in VEX, just like we do in ICE, and why there are different results in math.
This is interesting i think.
If you know the answers feel free to comment )))
Hakuna Matata ))) ahahahaha ))))
Re: porting ICE to VEX part 1
Post by Bullit » 07 May 2014, 19:24
So how it is your initial opinion about it?
nikaragua86
Post by nikaragua86 » 08 May 2014, 00:00
about VEX ? normal...its actually good - need to get used to it, but its good when you feel comfortable...i`ll continue to dig this porting topic,
and make more videos.
Post by Bullit » 08 May 2014, 13:36
About Houdini "ICE". I must say that the nodes are hideous. They remind me of particle flow.
Post by NNois » 08 May 2014, 20:09
Thanks you a ton for sharing you process, i'm following the same migrating path although i started more with the animation side. I must say houdini is fantastic and i've found than in softimage I was "workarounding" for many things and... not at all in houdini.
Bullit wrote:About Houdini "ICE". I must say that the nodes are hideous. They remind me of particle flow.
Yearrr, this is a constructive comment for going forward !
Post by Bullit » 08 May 2014, 23:17
Hehehe.
NNois can you tell us an example of a "workarounding" that doesn't happen in Houdini?
Post by NNois » 09 May 2014, 14:09
Bullit wrote:Hehehe.
There are plenty ! a simple and maybe bad example would be a clone, heavily used on softimage but doesn't update cluster and other things... in houdini this is a live "read" operator who start just where you want.
Another one, on softimage you load a model, he read it and paste it in your scene, and you go from there, if the file is modified you restarst from... the start. On houdini, the file is just read and used, if the file change everything follows. Just like you assets in after effect and nuke ;-)
Post by Bullit » 09 May 2014, 16:01
I see. I am in a problem with cluster and materials with a clone mesh. Is possible to copy cluster from one object to the clone? please answer in this topic https://www.si-community.com/forum/v ... =15&t=5188
