Layout Front View
Frank1000
Skype: the2he
Layout Front View
Post by Frank1000 » 06 May 2014, 01:03
when i edit the Layout, i can't find how to set a viewport to Front or Left / Right ... how does this go ?
Regards,
Frank
gustavoeb
Skype: gustavoboehs
Re: Layout Front View
Post by gustavoeb » 06 May 2014, 01:26
in the upper left corner of each viewport you can find the camera, the memocams and the letters X, Y and Z
when in the rightview middleclick the X button to flip the X axis and look from the left
when in the topview middleclick the Y button to flip the Y axis and look from the bottom
Gustavo Eggert Boehs
Frank1000
Skype: the2he
Post by Frank1000 » 06 May 2014, 07:47
Hi Gustavo,
my Layout Edit Screen doesn't show the cam / memo / view buttons
Post by Hirazi Blue » 06 May 2014, 13:35
What exactly do you want to achieve?
AFAIK setting the "View Manager" to a preferred view isn't possible when setting up a layout.
Such operations that change the viewport setup can however be scripted
and placed in an event (for example a siOnBeginNewScene event).
Frank1000
Skype: the2he
Post by Frank1000 » 06 May 2014, 14:12
i'm trying to make a layout with 5 windows, where 1 is an XSI-Explorer, then 3 is for Front / Top / Right and 1 is for perspective view.
Post by luceric » 06 May 2014, 14:44
In Edit Layout mode,
right click in the "View Manager" and select Set View Properties.
Select the layout and set the name of the cameras for each viewport, for example "top" for the camera name in B:
for the layouts, look at the doc
http://softimage.wiki.softimage.com/sdk ... ibutes.htm
Post by Hirazi Blue » 06 May 2014, 15:11
Interesting. I didn't know that. Thanks. ;)
Is setting this in Layout a fairly new option or has this been possible "always"?
Post by luceric » 06 May 2014, 15:30
the Layout attribute is probably from softimage 2010, or whenever Chinny added those layout buttons at the bottom left of the Softimage window
Post by Hirazi Blue » 06 May 2014, 15:32
Ah, that explains a lot...
I have learned that kind of stuff ages ago and hardly ever touch it... ;)
Frank1000
Skype: the2he
Post by Frank1000 » 06 May 2014, 16:11
ok i tried around with it but was not sure which of the 5 windows will be which viewport.
For example this
created that
my goal is this:
What would be the correct entries ?
Post by luceric » 06 May 2014, 18:14
it's not possible to have 5 viewports. You only get one view manager, which has 1 to 4 viewport.
Then you can use an object view if you need something else, but that's not going to behave like viewport you can switch to another view.
Frank1000
Skype: the2he
Post by Frank1000 » 06 May 2014, 21:33
ya i need only 4 viewports, one window is the XSI-Explorer ... but how would i fill out the View Properties right for that ?
Post by luceric » 07 May 2014, 02:53
Your expected result posted in the previous page doesn't make sense. When have you ever seen the view manager split with two views on top and three on the bottom? That's what my previous reply says, it splits at the maximum of 4 views, in a square way.
Post by FXDude » 07 May 2014, 05:17
gustavoeb wrote:in the upper left corner of each viewport you can find the camera, the memocams and the letters X, Y and Z
Never figured we could middle click on those to get that : ) thanks!
@Frank;
The "View Manager" natively has 4 viewports
(which is maximised by default since v2012, and which you can change in the prefs)
but in your layout, you were trying to setup additional viewports on top of those native 4.
(possible but inconvenient as LucEric pointed-out.)
Although by your screenshot notes.. (looking for Top, Persp, Front, Right.. which is the default anyway),
I think your just looking for a place to fit-in an extra pane among those 4.
But that "extra" XSIExplorer pane can only go besides or under the ViewManagers' four A,B,C,D Views, acting like a single entity.
Also (FYI), for general viewport manipulation,
(mostly useful interface extras with an API for scripting things otherwise rather tricky to GET and SET)
there is the awesome and *super stirdy* (while also old.. go figure) ViewportControls 2.0 from Chinny
http://traypen.com/rr/bak/chinny/viewportcontrols.zip
Which provides a number of things, (lots.. see below) but which I personally use for a few favorites ..
like a Tear-off camera view
which creates a floating Object View clone of you current view while setting *all* ObjectView attributes for it to behave *exactly* like a regular view,
.. also a "smart" (adaptive) camera auto-keyer,
various top level menu shortcuts to otherwise burried view properties,
and QuickFlix being like a settable 1 click Quicktime viewport capture..
Details...
Viewport Controls 2.0
New Viewport and Camera Commands (for artists)
in the viewports' Camera , Visibility and View menus.
_________________
* KeyCamera
If the active viewport is a scene camera
this will key :: the local rotation and translation and the field of view, projection and focal length.
If the camera has an interest it will also key the interest's local rotation and translation.
The Camera property page has a native "Allow Autokey During navigation" option to key selected cameras.
When ViewportControl's "Key Selected Cameras" is also on,
if your selection loosely contains:
Any Cameras, Camera Roots, Interests or Groups,
-- KeyCamera will find and key the Cameras and Interests within this selection,
(even if there are other things in the selection)
and will ignore the active viewport camera (unless it's part of your selection).
_____
* Spot Light View Menu
Any viewport can look through a spotlight.
As with cameras, SpotLights have a dedicated menu.
Key SpotLight will key the rotation and translation and on its interest if it has one.
_____
* Tear Off Camera
Creates an Object View out of any view including orthographic (top/right...) views
_____
* Create Light from View
If the viewport is a Perspective "User" or "Camera" view,
a spot light is created, with the cone angle matching the camera's field of view.
If the viewport is an orthographic top, right (etc) orthographic view, a an infinite is created.
_____
* Create Camera from View
This works for Scene Cameras and SpotLights with or without an interest.
If the viewport is a Perspective "User" or "Camera" view, a new camera is created
without an interest or a parent.
This is useful for camera texture projections, as the camera can be animated.
On creation the viewport switches to the new camera, which inherits the name from the view or light source
_____
* Isolate
AKA Isolate With Options
This opens a mini ppg which has a few more options than the normal Isolate Selected
When the mini ppg is closed it will Un-Isolate all Views
_____
* TurnTableCreate
Creates a turntable camera and a controls PPG
The controls PPG can be found under the turntable model
This can be used from any view
This will also work on a sub-component selection
_____
* QuickFlix
One click to capture the viewport playback.
with QuickCaptureOptions : A few settings not found in the normal capture options
_____
* Synoptic Toolbars
ViewportSynoptic
A synoptic toolbar for the most common viewport commands
ViewSwitcher
A mini synoptic for switching between Right, Top, Front, User, Camera
________________________
* New commands for scripting
- GetViewport
- SetViewport
- SetViewportLayout
- GetViewportNumber
- GetLightFromViewport
- CopyViewport
- GetSelFilter
- CamerasFromSelection
- StringList
- StringTrim
- DeleteBranch
- GetSceneName
- GetScenePath
[/quote]
Cheers!
[silent edit .. changed all links from sculptwork.com to traypen.com -rr]
Frank1000
Skype: the2he
Post by Frank1000 » 07 May 2014, 08:36
Hi Gustavo, k cool thx.
