SI2015 "no interactive network license"
Post by Hirazi Blue » 28 Apr 2014, 21:28
After an unrelated system crash and a subsequent Windows system restore I am faced with a somewhat bizarre and dreaded “no interactive network license” error and nothing I've tried so far has been able to fix this. I tried reinstalling, I checked the License.env, which is set to network and the correct server name and my previous Softimage 2014 SP1 still runs as advertised on the newly configured license server with the 2015 license file. Suffice it to say that I'm not amused and that I'd be very grateful to any help that can remedy this situation. What can I do to restore my Softimage 2015 license?
8-}
Re: SI2015 "no interactive network license"
Post by luceric » 28 Apr 2014, 22:18
maybe the firewall. it's free to contact support for help, btw
Post by Hirazi Blue » 28 Apr 2014, 22:22
That would be next course of action, but I'm still primarily a forum user... ;)
No internet connection, no firewall BTW.
Post by luceric » 28 Apr 2014, 22:41
isn't there a firewall in Windows? That often blocks the network socket used by licensing to contact even the local host.
Post by Hirazi Blue » 28 Apr 2014, 22:45
But wouldn't that block my Softimage 2014 SP1 as well, which does run on the 2015 license?
Post by xsisupport » 29 Apr 2014, 01:09
What does SoftimageLicense.log say?
What about the FLEXLM_DIAGNOSTICS? (in an si prompt, set that env var to 3 and try to start xsi.exe)
// Steve Blair
Post by Hirazi Blue » 29 Apr 2014, 08:34
Read'em and weep:
FlexNet Licensing checkout error: No socket connection to license server manager.
Feature: 86269SFTIM_2015_0F
License path: @LEENDERT-PC;@127.0.0.1;
FlexNet Licensing error:-7,10015
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
license file(s): @LEENDERT-PC @127.0.0.1
FlexNet Licensing checkout error: License server system does not support this feature.
Feature: 86270SIECS_2015_0F
FlexNet Licensing error:-18,147. System Error: 10061 ""
Feature: 863983DSMXS_2015_0F
Feature: 86400MAYAS_2015_0F
Feature: 86243ENCSU_2015_0F
Feature: 86272AAA_2015_0F
Feature: 86248ESEC_2015_0F
The "Feature: 86400MAYAS_2015_0F" surprises me somewhat, as I haven't officially defined my transition yet.
I did run a Maya 2014 and Softimage 2015 in trial mode before system recovery, if that helps clarifying anything.
Thanks in advance if you're able to look at this... :-bd
druitre
Post by druitre » 29 Apr 2014, 08:52
Perhaps silly to mantion, but I was kind of stumped too after installing 2015 until I installed the latest version of the flexlm manager. Maybe, after your system restore, it has reverted to the 2014 version?
Post by xsisupport » 29 Apr 2014, 09:17
True, you need the latest version of the NLM to run 2015 software.
The relevant part of all that FLEXLM_DIAGNOSTIC output is No socket connection to license server manager.
Note that xsi.exe tries for both Maya and 3ds Max licenses. It has nothing to do with your choice, that is there to support whatever transition choice you do make.
%TEMP%\SoftimageLicense.log is useful to rule out other problems (like .pit or .cas problems).
// Steve Blair
Post by Hirazi Blue » 29 Apr 2014, 11:41
:ymparty:
@druitre & @xsisupport – So, basically, it does help to read all the installation instructions...
Reinstalling the license server did indeed do the trick. Thank you both so very, very much!
A well-deserved virtual beer for the both of you and for luceric as well, obviously…
druitre
Post by druitre » 29 Apr 2014, 14:29
:ymparty:
bb3d
Post by bb3d » 14 Jul 2014, 20:51
@Hirazi Blue:
How did you generate your 2015 license?
I was used to generate my license files through the website registeronce.autodesk.com, but for some reason that doesn't work anymore, because after login all I get is a blank page. Tried this on different machines with different browsers.
I contacted support but instead of helping me, they asked for my server name and network ID, although I provided this information already. This was 2 weeks ago...
Post by Hirazi Blue » 14 Jul 2014, 21:11
Initially I got help from Jill Ramsay (AKA "jill.ramsay") of Autodesk. Maybe you can contact her, she has an account here, so you could send her a private message...
bb3d
Post by bb3d » 15 Jul 2014, 22:01
Thank you for the tip, but after some rant email Autodesk support was able to send me a working license file finally.
Softimage 2013 - 2015 working now :ymapplause:
Now waiting for response to the home use request, sent 2 weeks ago...
