Some CrowdFX compounds
CrowdFX - Override Bones AnimationAuthor: Hans Adrian (Autodesk)
Another goodie presented by Autodesk Intern Hans Adrian on the Softimage mailing list: Hey all, here is another CrowdFX Compound. This one is used to override bones animation. Demo - blending upper body with aim animation. [..] How to use: Execute 'Store Actor Hierarchy' compound - see attached 'Store Actor Hierarchy.PNG' In 'Animation Definition', connect 'Override Animation' to the animation state's pose modifier which you would like to override - see attached 'Animation Definition.PNG' Parent Bone is the bone which animation and descendants' animation (children, grandchildren etc.) will be overridden. You can find all bones that you could use from Crowd > Actors_Proxies > [Model]_mesh > Deformers_Proxy > [Bone Name] see attached 'Get Bone.PNG' For animation index, you can debug 'self.__CrowdFX_CycleNames' or go to 'Get_Animations_Sources' ICE tree of the crowd and get the index of the animation that you want (index is 0 based) 'On Condition' is the condition in which animation is overridden; if you would like the animation to override at all time, put it as true. Otherwise, you can use conditions. For frame mode, you have the options to manually specify which frame of animation you would like to use or you can put it on loop. 'Frame to Use' is the frame number used if you choose to specify the animation frame. Transition duration is the duration in which the overriding is being blended.
Also see the included Readme - Animation Blending system for CrowdFX.pdf
local backup: Store Actor Hierarchy.xsicompound Override Animation.xsicompound.xsicompound SoftImage ICE CrowdFX - Override Animation.scn (demo scene)
An extension was provided a week later, enabling the actors to trigger a secondary animation, in this case shooting bullets ( video demo / Readme - Shoot Bullet System for CrowdFX.pdf )
local backup: Shoot Bullets.xsicompound Is In Blending Mode.xsicompound Is At State.xsicompound SoftImage ICE CrowdFX - Shoot Bullets.scn (demo scene)
CrowdFX - Move Within Two CurvesAuthor: Hans Adrian (Autodesk)
An ICE compound that makes a crowd follow a path defined by curves on either side.
Usage instructions as posted on the mailing list: Create a new Crowd Scene Create two curves which will bound the crowd Put »Initialize Move Within Curves« compound in »Emit_and_Initialize« tree of the crowd — see attached »Emit and Initialize.PNG« Put »Move in between two curves« compound as Goal of the crowd in »Behavior« tree; use the two curves as input to the compound, with the left curve as Curve_Name_1 and right curve as Curve_Name_2 — see Behavior.PNG This compound works with and without terrain.
Additional material: A demo on youtube.
local backup: Initialize Move Within Curves.xsicompound Move in between two curves.xsicompound
CrowdFX - Group BehaviorAuthor: Hans Adrian (Autodesk)
An ICE compound for CrowdFX that makes groups avoid each other.
Usage instructions as posted on the mailing list: Create a new crowd scene with different social group ID Go to »Behavior« tree of Crowd Simulation Tree Replace »Set Velocity Using Collision Avoidance« with the attached compound »Set Velocity Using Group Collision Avoidance« (See Attached Group Behaviour.PNG) Tune »Far Interaction Limit« (found at »Emit_And_Initialize« tree > »Initialize Collision Avoidance«) for better result. Using 70 as the value seems to give overall best result for most cases.
local backup: Set Velocity Using Group Collision Avoidance.xsicompound
Post by Hirazi Blue » 24 Apr 2014, 12:04
On the Mailing List Hans Adrian (Autodesk) presented two new compounds for CrowdFX.
They can be downloaded as a zip from here.
Moderator edit: changed the title from "2" to "some, as there are three already - HB
Re: Some CrowdFX compounds
Post by Bullit » 25 Apr 2014, 04:34
Many thanks.
Post by Hirazi Blue » 12 May 2014, 08:11
From the Mailing List, posted by Hans Adrian (Autodesk):
This would be an extension of the CrowdFX compound on blending two animations. This enables the actors to shoot bullets when animation is blended.
How to use:
- Execute `Store Actor Hierarchy` compound - see attached 'Store Actor Hierarchy.PNG'
- In `Animation Definition`, connect `Override Animation` to the animation state's pose modifier which you would like to override - see attached 'Animation Definition.PNG'
- Parent Bone is the bone which animation and descendants' animation (children, grandchildren etc.) will be overridden. You can find all bones that you could use from Crowd > Actors_Proxies > [Model]_mesh > Deformers_Proxy > [Bone Name] - see attached 'Get Bone.PNG'.
- For animation index, you can debug `self.__CrowdFX_CycleNames` or go to 'Get_Animations_Sources' ICE tree of the crowd and get the index of the animation that you want (index is 0 based)
- 'On Condition' is the condition in which animation is overridden; if you would like the animation to override at all time, put it as true. Otherwise, you can use conditions.
- For frame mode, you have the options to manually specify which frame of animation you would like to use or you can put it on loop. 'Frame to Use' is the frame number used if you choose to specify the animation frame.
- Transition duration is the duration in which the overriding is being blended.
Download it from here.
Post by wireframex » 12 May 2014, 17:02
Suppose it doesn't work with SI2012 ?
Phil
Post by Bullit » 17 May 2014, 21:06
I don't think there was crowdFx in 2012.
