Including a command line executable tool with a .xsiaddon
Manticor
Post by Manticor » 23 Apr 2014, 12:31
Hi there
Im currently finishing up a custom exporter plugin in python but Ive ran into a bit of a problem .I would like to include a command line executable as part of the package which I can run from python (its basically a texture converter .exe) .But I'm not 100% sure where it will be installed when someone installs it.
Can anyone suggest a good way of solving this problem ?
Re: Including a command line executable tool with a .xsiaddon
Post by Hirazi Blue » 23 Apr 2014, 13:33
One way that might work is the following: using “__sipath__” from the sipyutils module you can get the path to your script plugin from within the script itself, I believe. As the hierarchy of your addon doesn’t change, merely its location, you can use this “__sipath__” as a basis to get to the necessary other file. You'll have to dissect the path given by "__sipath__" a bit, but that's a relatively minor problem.
:-s
Manticor
Post by Manticor » 23 Apr 2014, 14:31
Thanks for the speedy help Hirazi.
myara
Post by myara » 24 Apr 2014, 10:07
You can get your Plugin Path with :
Application.Plugins( "PluginName" ).OriginPath
that will most probably will be:
Normal installation (user folder):
users\[userName]\Autodesk\Softimage...\Application\Addons\[AddonName]\Application\Plugins
Workgroup installation:
[Workgroup]\Addons\[AddonName]\Application\Plugins
M.Yara
Manticor
Post by Manticor » 28 Apr 2014, 08:02
Thank you myara.
I found to my dismay that pyutils isn't available to me as Im using XSI 7.01 here at work.
So your method works for me .
Kenny
Post by Hirazi Blue » 28 Apr 2014, 10:18
Friendly suggestion: when using an earlier version, specifying this version when asking questions could prove to be helpful to both parties! :D
Manticor
Post by Manticor » 30 Apr 2014, 11:21
My apologies Hirazi .I will mention it from now on.
