ICE and construction modes
Post by rray » 15 Apr 2014, 22:27
Hi all! Is it possible to access geometry data from a scene reference (point clouds, polygon meshes) using a different construction mode? (get data->geometry seems to use secondary shape always)
I remember some time ago there were shared ICE tree nodes visible inside the referenced objects (which might have been movable to a different point in the stack). But these have disappeared in some past version IIRC.
-rr
Re: ICE and construction modes
Post by NNois » 16 Apr 2014, 07:06
maybe i don't understand well but the clone point node do just that, you can move the reference in the stack. Is it that ?
Helli
Post by Helli » 17 Apr 2014, 21:39
What do you want to access ?
You could store attributes on your input geometry in the operator stack you want to have it in.
And then read those attribues.
Post by rray » 18 Apr 2014, 15:18
Yes something similar to what clone point does but for "get data" (set to geometry).
I would need it to get locations (which to read point positions from). I could store them in an attribute but I think they would compute from the geometry from the top of the stack not from where they were stored.
