Normal map doesn't work with wrap UV
KLONOA WORKS
Post by KLONOA WORKS » 15 Apr 2014, 16:50
hi guys,
I don't know what is missing, but the normal map doesn't work with wrapUV as in image show :
so any help :)
rpmaguire
Skype: eyekeystudio
Re: Normal map doesn't work with wrap UV
Post by rpmaguire » 15 Apr 2014, 23:55
Could be the texture repeats settings in the normal map properties
KLONOA WORKS
Post by KLONOA WORKS » 16 Apr 2014, 02:27
rpmaguire wrote:Could be the texture repeats settings in the normal map properties
I tried but doesn't work. :-\
MikeM
Post by MikeM » 25 Apr 2014, 07:04
Tested this, same issue (Softimage 2013), the only quick solution I could find is to set the texture repeats on the XSINormalMap shader node instead of using the uv space warp.
