Post
by Draise » 11 Apr 2014, 21:49
Yeah, one has to make sure your images are at similar dimensions, also use the math composite node, you need to keep an eye on what you're using to composite the two images - "screen" from a "Math Composite" node is probably what you were looking for. Also gotta make sure they have an alpha channel in your images, but by the looks of it is was fine with "Over".
Just.. some simple things to keep in mind,
