displacement to poly
rpmaguire
Skype: eyekeystudio
Post by rpmaguire » 10 Apr 2014, 22:49
Is there a "displacement to poly" option in softimage 2013?
Thanks,
-Ryan
angelous4x
Re: displacement to poly
Post by angelous4x » 11 Apr 2014, 00:18
in ice, you could use push_inICE node or the Push_texture.
give the object a texture map with the image you want to use. make sure you have the projection selected. then give the object an ice tree. get push_texture node. then bring in the "get point texture map color" and plug that into color. and make sure you have enough detail on your mesh.
csaez
Skype: csaezmargotta
Post by csaez » 11 Apr 2014, 00:59
Or you can simply connect a texture map to a push deformer :)
angelous4x
Post by angelous4x » 11 Apr 2014, 02:23
yes that way is way simpler. :)
