Shape Animation not working?
Shredder565
Post by Shredder565 » 09 Apr 2014, 17:47
For some reason, every now and then, the Shape Animator just refuses to work. The base scene model works when I open up it's original file. But for some reason, whenever I insert it into this particular scene, it doesn't want to work at all. I move the slider, and the animation does not deform like it is supposed to. Other scenes it works perfectly. nothing is different.
any ideas?
grendizer
Skype: uforobotgrendizerus
Re: Shape Animation not working?
Post by grendizer » 11 Apr 2014, 10:37
You're exporting a model from one scene and importing it in another scene? Are you using reference models? Are you using merge scene instead of exported models?
Shredder565
Post by Shredder565 » 14 Apr 2014, 20:11
grendizer wrote:You're exporting a model from one scene and importing it in another scene? Are you using reference models? Are you using merge scene instead of exported models?
Yes to the first question. no to the second. I tried to merge it with a new scene, and same effect.
i finally decided to close the project and start fresh with a whole new scene. for some strange reason, it worked the second time around. highly annoying
