How to set the alpha channel
Pancho
Post by Pancho » 16 Mar 2014, 14:23
Well, not so experienced in SI rendering. In LW or Modo I can easily set the alpha value in the material and in the render channels whether I want pre- or unpremultiplied rgbs.
How do I do this in SI (e.g., one object white alpha unpremultiplied, while background black alpha)? Especially in Redshift?
Google spits nothing out, only alphas used for texturing.
Cheers!!!
Pancho
Re: How to set the alpha channel
Post by Pancho » 16 Mar 2014, 18:32
No one? Unfortunately I can't find anything on this subject. Do I need to create some funky multi color matte and render the whole stuff twice? The alpha channe would be sufficient for me if I can just isolate my main object.
Unpremultiply with Alpha in Redshift? Anybody? Owei?
angelous4x
Post by angelous4x » 16 Mar 2014, 19:38
not sure havnt played with RS for a while. but if you look into there forms or documents I am sure you could find it.
www.redshfit3d.com
Pancho
Post by Pancho » 16 Mar 2014, 19:46
Nope! Looked twice through it. Either I'm blind or it's not there.
Post by NNois » 17 Mar 2014, 08:07
hi,
with mental ray
1, there is the opacity shader doing just that ;-), just plug your network into it
2, If it's don't work you can also try driving the "alpha" doing some input/output gymn: out of your shader tree use 3 "picker" each one a channel R, G, then B then combine them in a RGBA combine node, driving then the alpha can do the trick.
3, you can also take the AOV route (aka render channels), take a color 4 passthrough the plug your shader in it. Add a channel the plug a scalar store scalar in channel, drive the opacity here, you won't see anything but you'll have your opacity alpha for your comp ;-)
with arnold, i think you can just drive the opacity parameter but also unchecking the "opaque" switch
don't know for the others
Noël
