Comb Hair Using Curves?
TheRazorsEdge
Post by TheRazorsEdge » 14 Mar 2014, 07:11
Hi all,
from what I understand Si hair is bascially Joe Alter's Shave&Haircut/Max Hair&Fur.
In both Max and Maya there's a "(Re-)Comb Hair Using Curves"-function. Can this be done in SI as well?
There's nothing like that in the Hair menu as far as I can tell, but I'm wondering if maybe there's another way to do this or it's "hidden" somewhere?
If not is there a way to import styled hair from Max/Maya?
Cheers!
Re: Comb Hair Using Curves?
Post by rray » 14 Mar 2014, 12:23
For strands i made an ice compound which does that, I'll post it next week when I'm back from vacation. Interpolation will be a bit different probably to those systems.
TheRazorsEdge
Post by TheRazorsEdge » 14 Mar 2014, 16:43
That sounds very cool! Looking forward to it! :)
But I'm guessing that means there's no way to do it with regular hair?
Cheers!
Post by rray » 21 Mar 2014, 17:17
Here it is, you need existing hair root points for it. If you need a compound for that, I can post that too.
Plug any number of guide curves in and it interpolates the strands, either in global space or something I called "scalp space" which looks better imho.
Let me know if it's easy enough to use.
It requires these compounds being installed:
https://www.si-community.com/forum/v ... =19&t=4936
TheRazorsEdge
Post by TheRazorsEdge » 23 Mar 2014, 12:01
Thanks a lot for the compound and instructions.
rray wrote:Here it is, you need existing hair root points for it. If you need a compound for that, I can post that too.
That would be great.
I'll give this a good try when I have some free time.
Thank you very much again!
Cheers!
