Color map
ajhorvath
Color map
Post by ajhorvath » 17 Feb 2010, 06:39
Does anyone knows why I can't see the texture color on my render?
Thanks for the help!!
Re: Color map
Post by Hirazi Blue » 17 Feb 2010, 08:21
Could it be, you forgot to include the necessary Attribute Shader (Color) in your Render Tree?
ajhorvath
Re: Color map
Post by ajhorvath » 17 Feb 2010, 08:49
It could be.I have to check it out,
Zarvosa
Re: Color map
Post by Zarvosa » 19 Feb 2010, 08:34
ajhorvath
Re: Color map
Post by ajhorvath » 19 Feb 2010, 09:14
Thanks for the help Zarvosa,
This is the setup that I got.I have a Color Map.where would I get the Attribute color?
Thanks a lot!!!
Re: Color map
Post by Hirazi Blue » 19 Feb 2010, 09:23
I'm not sure, but you probably won't need the image clip in your Render Tree, as you are already driving the color parameter in the ICE Tree with it. Drag the Attribute_Color shader into your Render Tree, connect it to the diffuse parameter in your Phong shader, open up the Attribute_Color shader to set the attribute that is actually used from "Default" to "Color". Now it should work (I hope... :- )
