Is there a python script that closes any open floating windows a script uses like the expression editor for example.
Thanks,
Max
Closing floating Windows after a running a script-Python
maxcrow
Re: Closing floating Windows after a running a script-Python
Don't know of any "ready-made" script, but this should be fairly easy to implement utilizing the view object and setting the view.state, especially if you already know which views your script has opened.
maxcrow
Thanks Hizari,
That link helped and I have been informed by Andrew Hazelden http://www.andrewhazelden.com this may be the best way to do it
# Stop the PPG Windows from opening
Application.SetValue("preferences.Interaction.autoinspect", False, "")
AndrewHazelden
Hi Max.
Here is a python script example that will close a specific window:
# Python Script - Close the Expression Editor window
def closeExprWindow():
# Window States
siNormal = 0
siClosed = 1
siMinimized = 2
# Target Window Name
targetWindowName = "Expression Editor"
# Get the active window list
layout = Application.Desktop.ActiveLayout
views = layout.Views
for x in views:
if str(x) == targetWindowName:
# Change the current window state to siClosed (1)
x.State = siClosed
print("The "+str(x)+" window has been closed")
# Close the Expression Editor window
closeExprWindow()-
csaez
- Skype: csaezmargotta
There is a third argument on AddExpr() command to prevent the Expression Editor from appearing automatically (or use the OM)
http://download.autodesk.com/global/doc ... dExpr.html
