Extracting Multiple Masks from a Single Constant Image?
Rez007
Post by Rez007 » 28 Feb 2014, 22:39
I have a question that I am hoping someone can help me with. Is there a way in post (Softimage FX Tree) to either create or extract a mask from a single image of constant colors? More-or-less to isolate a constant color and generate a mask from that, all in post. I attached some simple references that I made quickly to give an example of what I am looking to do. I would need the mask to be crisp, as well. Sorry if it is an easy question, just drawing a blank...Thank You.
Base Image
Resulting Mask_1
Resulting Mask_2
Resulting Mask_3
Resulting Mask_4
Resulting Mask_5
Thank You in Advance for the Help!
Re: Extracting Multiple Masks from a Single Constant Image?
Post by rray » 28 Feb 2014, 22:45
This is what 'keyers' usually do. Not sure but probably the FX Tree has such a node.
Rez007
Post by Rez007 » 01 Mar 2014, 18:42
rray wrote:This is what 'keyers' usually do. Not sure but probably the FX Tree has such a node.
Thank you rray for the help. I think I was doing it wrong so I will check it out better. Thanks!
Skype: ondraise
Post by Draise » 01 Sep 2014, 20:34
Color Key/Extract or Luminance key/Extract also works too no?
Post by FXDude » 02 Sep 2014, 02:03
Ya FXTree keyer is -really- straight and simple, you can click on the color that you want to pick, and show the matte, and perhaps adjust ranges (in RGB or HSV) for the gradients or aliasing areas
( 1 keyer for each color)
Or a also, here you have 5 colors, but If you can settle for 4, you can put each tile in their own RGBA channel and have worry-free clean results.
