Is there any way to constantly turn off weight map visibility so it didn't appear after each move of my camera in paint tool mode or weigh map mode ?
I need only shaded mode and don't wont it to reset to constant+weigh map after each manipulation in viewport.
WeighMap-ShadedMode
Re: WeighMap-ShadedMode
Could be that I misunderstand the question, but couldn't you just simply turn off the display of weight maps in the drop-down menu that hides under the eye-icon at the top of the viewport?
Superpositivo
For a strange reason, turning off Weight Map from the Eye Icon doesn't work.
Weight map display turns on automatically (I think it's a bug, maybe we could make a bug fix request for 2016?...err..)
sonictk
You can try turning off Property Maps in the Visibility Options as well but that doesn't sound like default behaviour. Do you mean that anytime you rotate your viewport while not in weight painting mode, it defaults back to Constant shading with the weights visible?
Bravlin Pechatnik
Exactly. But only in paint tool mode aka weight painting mode
