Array question
Array question
Post by rray » 27 Feb 2014, 14:47
Is there a way to get a "grouped" sum array like this without a repeat loop, for any size of group?
[ 0, 3, 7, 22, 6, 71, 1, 0, 9 ]
-> [ 0+3+7, 22+6+71, 1+0+9 ]
-> [ 10, 99, 10 ]
Group size (here 3) would go as an input into the compound
-rr
Re: Array question
Post by Mathaeus » 27 Feb 2014, 15:36
Should be, by using separate array, array size equal to group size, indices of that array for selecting in original array. For next group, indices + size of previous group, or something like.
I think I was able to get separate result for strand array, in similar way. ID of strand segment as size of new array, used for selection.
Now I have no idea how to automate this, without using loop - but, if size of group is always the same, should be possible to go with some modulo/divide trickery.
Re: Array question
Post by rray » 27 Feb 2014, 16:08
Thanks Anto, it would have to work for any number of groups too, so I probably won't get around coding something.
Trying to figure out the most general purpose design of the node. Maybe it could cover cumulative sums too.
Re: Array question
Post by xsisupport » 27 Feb 2014, 17:41
You can do somethingwith Generate Sample Set.
// Steve Blair
Re: Array question
Post by rray » 27 Feb 2014, 18:15
Hey thanks Steve! Nice, never occured to me that a set doesn't have to represent something in the scene.
I'll still do an attempt to write the custom node and if I'm successful do some performance tests of the two methods.
Re: Array question
Post by rray » 27 Feb 2014, 23:52
Did this https://www.si-community.com/forum/v ... =19&t=4936
I can't do the 'announced' performance test with big point clouds because I can't seem to get the GenSampleSet setup working with per point contexts.
