snapping points at 0 AXYS
hidalgo
Post by hidalgo » 15 Feb 2014, 16:13
Hey guys,
seems crazy, but i can't find a way to snap a bounch of points all, for example to the 0 point on the x axys, i can do it for one single point, but if i grab them all and type in the transform 0 they dont go to 0, but move proportionally to theyre original position, i have search for the same stupid little thingy everywhere, but i couldnt find anything about it.
thank you
Re: snapping points at 0 AXYS
Post by Hirazi Blue » 15 Feb 2014, 17:05
Not 100% sure (and I can't check ATM), but it sounds as if you'd have to enable "Collapse Points For Snapping/Absolute Translation" in the "Preferences > Tool Preferences > Transform Preferences".
hidalgo
Post by hidalgo » 15 Feb 2014, 17:08
thanks Hirazi, actually that trick was not working i tried, but for anybody like me who have found himself on the same problem, its enough to select the point go to scale set it to global and un thick COG then in the scale value (for example x) type 0 and voila' the points are all at zero.
AceMastermind
Post by AceMastermind » 15 Feb 2014, 23:06
Here are some scripts/plugins that can automate this operation:
hidalgo
Post by hidalgo » 16 Feb 2014, 08:27
Thanks for the help AceMastermind those will come handy
Pooby
Post by Pooby » 16 Feb 2014, 10:58
If you scale them to 0 in that axis it will work
hidalgo
Post by hidalgo » 16 Feb 2014, 12:35
thanks man, i actually wrote it already in my post above :D
