Post
by mc_axe » 20 Feb 2014, 12:18
Hmhmhmm not an ice expert heh but, you can try simulate an ice cloth (a grid almost same shape as the eyelash), and then mimic somehow its movements?
You can use syflex
Do sim on a cloth as you like, you will get fine results on that, i believe.
Add all points in one cluster. name it for example mimic_this_pointcluster .
and then use Syflex mimic to mimic the motion on the new object. (eyelash base)
Then u can add geometry on that base.
Not sure of the outcome . *Did some tests kinda worked. but changes behavior by adding new geometry
