3dsmax texture shaders for mental ray in softimage
nospitters
Post by nospitters » 03 Feb 2014, 15:53
hi,
is it possible to use 3dsmaxshaders.mi and 3dsmaxshaders.dll for mental ray also in softimage?
i just copied these files to softimage corresponding folders and i can see the nodes, but they render all black. is there a trick?
i am interested in the procedurals 3dmax offers also for mental ray.
The Soulcage Department
http://www.soulcage-department.de
Re: 3dsmax texture shaders for mental ray in softimage
Post by Mathaeus » 03 Feb 2014, 18:59
I'm afraid it's just impossible. I think procedural textures in Max are created by 3d app, not by particular renderer. That's why you can see them in viewport. Don't believe if there any texture generator in this dll. And, dll is, most likely, just a part of entire system.
Anyway, if there is no something completely new in Max, I think you should be able to get something close, using two integrated Binary Alchemy shaders in SI, fractal scalar and cell scalar.
Algorithms are pretty much the same across all 3d apps.
nospitters
Post by nospitters » 03 Feb 2014, 19:20
no thats not true.
i got it workin, but not perfect.
i edited the mi to have only the procedurals (noise, cell, marble, bricks, checker, dent, falloff, etc) declared.
the nodes require some coordinates like projection lookup...
cells and dent work pretty well, but noise will render only some buckets. other buckets are black or gray...
btw falloff works also well...
Post by Mathaeus » 03 Feb 2014, 22:07
nospitters wrote:no thats not true.
well I think both of us are 'true'. Most likely, they created parallel generators, as Mental Ray seems to be 'out' of Max render API. Still, I think this is a very risky business. Unless you are able to code all these shaders, I'd say, don't do that.
