Softimage --> CAD --> Physical Product (?)
Rez007
Post by Rez007 » 30 Jan 2014, 18:29
Hi Everyone,
I have a question to see if anyone knows how to get a model that was concepted/created in Softimage into a CAD format, to eventually be built as a physical machine. Are there any exporters/programs that do this and has anyone had any success?
If this is not possible, could anyone recommend a CAD software that is nice to work whom had experience building a physical machine. Is Solidworks the best, or would Autodesk Inventor be a better option? I have also heard that Rhinoceros is good too.
Any suggestions and advice would be very helpful. Thank You in advance.
Re: Softimage --> CAD --> Physical Product (?)
Post by Bullit » 30 Jan 2014, 18:58
Without knowing more it is a shot in the dark.
Depends on complexity of the machine how the components will be build . If it is simple and you only need to build the components then Solidworks or Inventor aren't really necessary. If you only need dimensions even Sketchup or a 2d cad program can do the job.
If you can't do in Nurbs in Softimage then Obj file probably is the best bet out of Softimage. Then you can use Meshlab(free) to convert to STL.
Be careful that your model is without holes in meshes.
Like i said it depends the complexity.
Rez007
Post by Rez007 » 30 Jan 2014, 19:12
Hi Built,
Thanks for the feedback. It is more of a complex design that will have operating machinery/parts (plastic parts that move or hinge based where the person can open a panel on their own.) It would also house electronics on the inside...almost like a register or mini-computer. I've tried Surfaces (nurbs) in Softimage before, but they were kind of a pain...
Thank you for the advice and I will look into those as well.
Post by Bullit » 30 Jan 2014, 19:25
You can do it with MOI 3D which is a Nurbs modeler that is probably the cheaper one.
So the whole object is plastic?
Rez007
Post by Rez007 » 30 Jan 2014, 19:56
Bullit wrote:You can do it with MOI 3D which is a Nurbs modeler that is probably the cheaper one.
Thank you for the MOI 3D. I will have to check it out, I think it also depends a lot on what route the client wants to take. I am looking to find out in advance to see what might be best, and most cost-efficient.
Well, not really all plastic. A lot of things nowadays are plastic injected molds, and there will be electronics and some metal aspects to it as well, I believe.
Post by Bullit » 30 Jan 2014, 22:35
Do you already know how many components it will have? Nothing precise, just a ballpark.
Rez007
Post by Rez007 » 30 Jan 2014, 23:25
Bullit wrote:Do you already know how many components it will have? Nothing precise, just a ballpark.
To be honest, I really don't know as there will be quite a bit of internal parts I believe. I just did the main design while keeping everything in mind, but not the internals...
Nizar
Post by Nizar » 06 Feb 2014, 20:55
I do the job of fast prototyping practical everyday. Did you mean this (prototyping) for physical machine?
Rez007
Post by Rez007 » 06 Feb 2014, 22:10
Nizar wrote:I do the job of fast prototyping practical everyday. Did you mean this (prototyping) for physical machine?
Hi Nizar,
I have the concept design done in Softimage, and I was just seeing what recommendations people had for either bringing it into a CAD environment, or if that didn't work cleanly, what CAD software they would recommend as a good candidate to remake the machine. (I believe it would have to handle pretty precise measurements and be accurate as well.) Do you use a certain CAD software that you like?
Thank You.
Nick3d
Post by Nick3d » 07 Feb 2014, 12:50
As far as product design and in general prototyping I always used Rhinoceros
In Softimage, due to the lack of proper precision editing and freeform modification, I always ended up creating the finished product to send to the customer ( beauty render for preview ), then export the mesh to Rhinoceros, scaling/adjusting everything in order to match the dimensions, then re-build the mesh inside Rhinoceros using the mesh from Softimage as a base, tweaking the geometry to make it easy to build with plastic molding, then export everything as a STL
For everything else ( non design products ) I use Solid Works or Solid Edge
Rez007
Post by Rez007 » 07 Feb 2014, 21:44
Nick3d wrote:As far as product design and in general prototyping I always used Rhinoceros
Thank you very much for the reply and advice. That sounds like an option for sure. I tried Rhinoceros way back in the day, and I really liked it.
Nizar
Post by Nizar » 09 Feb 2014, 17:46
I doing characters for 3d printing. For my need softimage, zbrush and nettfabb are more enough
Netfabb is a free software (also exist a pro version), can measure your model and the mesh for printing:
http://www.netfabb.com/
don't use any cad software.
Rez007
Post by Rez007 » 09 Feb 2014, 18:15
@Nizar, Thank you for letting me know. I will take a look at it.
