restart Softimage
missingkey
restart Softimage
Post by missingkey » 23 Jan 2014, 23:03
Hey All,
I was just been familiarizing myself with self-installing plugins, and just thought I'd share...
It's a restart softimage command... Hoooraayyyyyy!!! lmao
It adds a "Restart SI" command to the file menu, closes your current SI session (without saving), and opens a fresh SI App.
There is also a command "Save Kill Restart Reopen", which saves your current scene, kills SI, reopens SI, reopens your scene
and Another command to just open up another instance of the SI app.
As simple as it sounds, It's kinda nice having it. Enjoy!
Re: restart Softimage
Post by Hirazi Blue » 23 Jan 2014, 23:09
I am sure the "without saving" feature will make it a.veritable hit.
But seriously: thanks, might come in handy!
missingkey
Post by missingkey » 23 Jan 2014, 23:30
Hey Thanks!
I just updated it to be linux friendly. It doesn't work in linux yet, but it's friendly. lol
btw, it's nothing pretty, it just kills the process. Use at your own risk.
missingkey
Post by missingkey » 24 Jan 2014, 00:14
okay it works in linux too now. I updated the linked file in the first post.
sorry for the confusion.
Post by Hirazi Blue » 24 Jan 2014, 09:50
You might want to explicitly clarify if the version in your first post has already been updated to the Linux one or not.
missingkey
Post by missingkey » 24 Jan 2014, 19:47
Hi, Yeah, sorry for the confusion. I removed the file from my previous post, and updated the file linked in the first post.
I'm working on another option for saving the scene, killing SI, and reopening the scene.
It works well when I'm working on an existing scene. But I'm trying to throw in a condition that when the scene name is "Untitled", it does a "SaveSceneAs", then i'm trying to get the current project and scene after saving it, So that I can reopen them when SI relaunches, but it doesn't define the new variables correctly or maybe not quick enough, and SI just starts with an empty scene.
any ideas?
def saveKillRestartSI_Execute(  ):
	si = Application
	log = si.LogMessage
	import os, sys
	import subprocess as sub
	from signal import SIGTERM
	pid = os.getpid()
	scene = str( si.ActiveProject.ActiveScene ) + ".scn"
	project = str( si.ActiveProject )
	scenePath = project + "/" + scene
	def saveKillRestartSI():
		if sys.platform == "linux2":
			siPath = os.getenv( "XSI_BINDIR" ) + "/XSI.bin"
		elif sys.platform == "win32":
			siPath = os.getenv( "XSI_BINDIR" ) + "/XSI.exe"
		else:
			log( "Dude, what OS are you using?" )
		if scene == "Scene.scn":
			si.SaveSceneAs()
			scene2 = str( si.ActiveProject.ActiveScene ) + ".scn"
			project2 = str( si.ActiveProject )
			scenePath2 = project2 + "/" + scene2
			sub.Popen( [ siPath, scenePath2 ] )
			os.kill( pid, SIGTERM )
		else:
			si.SaveSceneAs( scenePath )
			sub.Popen( [ siPath, scenePath ] )
	saveKillRestartSI()
myara
Post by myara » 30 Jan 2014, 06:02
It does open the saved scene here, but it doesn't kill my SI. I haven't installed Python in this PC, only using the SI default python so that may be the cause.
I see also that it doesn't use xsi.bat but xsi.exe so it doesn't run setenv.bat which may not be a good thing.
And btw, the File name isn't always the same as the scene name so you may want to get ActiveScene.FileName.value instead.
M.Yara
missingkey
Post by missingkey » 30 Jan 2014, 07:54
Hey thanks, that's great feedback.
I'll have to look into why it doesnt work with just Si python. Seems strange.
I also didn't know about using xsi.bat instead of xsi.exe, or about the file name. Many thanks! This helps me a lot.
Post by luceric » 30 Jan 2014, 11:52
you should call the Quit() command. if you kill Softimage, that's gonna be reported to autodesk as an unclean crash exit.
all you needed to do quit Softimage without saving was to call NewScene with the False parameter to not save the scene, before calling Quit()
missingkey
Post by missingkey » 30 Jan 2014, 15:22
Haha, That is much simpler, many thanks for the tip. I had a feeling there was a way to do within SI, and not have to use os.kill()
This is really helpful, thanks guys!
Is there a way so that when SI reopens, it doesn't ask to save the empty scene before loading your saved scene?
Post by luceric » 30 Jan 2014, 15:32
It shouldn't be asking to save on an empty scene. Maybe a plug in dirties the scene. Anyway
running "Xsi.bat (name of the scene)" should load the scene directly.
Post by Hirazi Blue » 30 Jan 2014, 16:00
Is there any easy way to figure out which plugin would cause this?
The described problem has been one of my "small annoying things" for years now...
~x(
missingkey
Post by missingkey » 30 Jan 2014, 16:22
so in the past. It hasn't done this (at least for me). If I never changed/dirtied a fresh new "untitled" scene, it would never ask me to save. But now, It almost seems like no matter what. SI asks if I want to save.
I'd love to figure this out, lol.
csaez
Skype: csaezmargotta
Post by csaez » 30 Jan 2014, 16:23
Hirazi Blue wrote:Is there any easy way to figure out which plugin would cause this?
~x(
print [e.Name for e in Application.EventInfos if "Startup" in e.Type]
missingkey
Post by missingkey » 30 Jan 2014, 16:27
this is my output from the line of code above:
#  [u'XSISeqCamStartup', u'OnStartupInitNetview', u'OneClickStartup', u'XSI_Startup', u'mi_decl_fixup_startup', u'RTShaderSetCategoriesEvent']
Not sure where to go from here. lol.
Post by Hirazi Blue » 30 Jan 2014, 16:28
csaez wrote:
But that would give you a list of Events at Startup, not necessarily the plugins that dirty the scene in the manner described above? Or am I missing something here?
