Curve To Ribbon
Curve to Ribbon Video demo. Curve to Ribbon generates polygon mesh strips based on input curves. There are settings
for subdivision, thickness, center and offset as well as for the ribbon plane: XY,
XZ, YZ or auto. Works with multiple curves and even merged curves. Requirement: »keyvis Curve Tools« by Eugen Sares (moved directly below).
local backup: CurveRibbon.xsiaddon
julca
Curve To Ribbon
Hello,
I want share with you my last plugin.
It create ribbons from curves.
I use the offset command from the "keyvis Curve Tools" addon created by Eugen Sares.
It create a perfect base before the loft.
So, you need to have this addon already installed (but who did not ;) ?) if you want use mine.
"Curve To Ribbon" have a custom property witch drive all proxy parameters from the differents meshes/operators.
Quick video demo :
Cheers.
Quick video demo :
Cheers.
Re: Curve To Ribbon
He,
That's a neat little tool!
Thanks for sharing, much appreciated!
EDIT: Just tested it here, but getting python errors and an OLE message. It does create the curves, but no geometry.
SI 2013SP1, installed the .xsiaddon in a server workgroup.
julca
Re: Curve To Ribbon
Thank you guys !
Can you give me your model for a test ?
I just test it with 2013 SP1 (in a custom workgroup) and it work on my side.Rork wrote:Just tested it here, but getting python errors and an OLE message. It does create the curves, but no geometry.
Re: Curve To Ribbon
didn't do anything special. created a sphere and created the curves like in the video.
after that ran your tool.
retried with a couple of restarts of SI as well, same result. I do run the SI internal python thingy btw..
julca
Re: Curve To Ribbon
I also run SI internal Python.
Can you send me your log ?
Re: Curve To Ribbon
This is what I get after selecting the extracted curve and running the tool:
Application.SelectObj("crvlist", "", "")
# File "<Script Block 2>", line 43, in curveRibbon_Execute
# firstCheck()
# File "<Script Block 2>", line 358, in firstCheck
# main(collOfCurveSelection)
# File "<Script Block 2>", line 82, in main
# customOffsetCurve(collOfCurveUniqueLeft, gRibbonWith * -0.5, collOfAllOffsetOpLeft)
# File "<Script Block 2>", line 322, in customOffsetCurve
# xsi.ApplyOffsetSubcurves(inCollOfCurveToOffset.GetAsText())
# File "C:\Program Files\Autodesk\Softimage 2013 SP1\Application\python\Lib\site-packages\win32comext\axscript\client\pyscript.py", line 142, in __getattr__
# return getattr(self._scriptItem_.dispatchContainer,attr)
# File "C:\Program Files\Autodesk\Softimage 2013 SP1\Application\python\Lib\site-packages\win32com\client\dynamic.py", line 500, in __getattr__
# raise AttributeError, "%s.%s" % (self._username_, attr)
# AttributeError: Application.ApplyOffsetSubcurves
# - [line 321 in \\SERVER\xsiwg\Tools\Addons\CurveRibbon\Application\Plugins\curveRibbon.py]
# ERROR : OLE error 0x80020101
Application.curveRibbon()
hope that helps,
# firstCheck()
hope that helps,
julca
Re: Curve To Ribbon
It's seems that you don't have the "keyvis Curve Tools" addon installed.# AttributeError: Application.ApplyOffsetSubcurves
Can you check this ?
Re: Curve To Ribbon
Ah... that makes sense.
I misread your comment on the Keyvis Curve Tool. I was under the impression you used that part of the code.
But you use the plugin as well to get to this.
Problem solved! ;)
Problem solved! ;)
julca
Re: Curve To Ribbon
Cool !
I use my own extract subcurves code but use the "ApplyOffsetSubcurves" command from the "keyvis Curve Tools" addon.
druitre
Re: Curve To Ribbon
thanks Julca, this one saved my ass today
- Jasper
- Jasper
julca
Re: Curve To Ribbon
Cool ! I am very pleased that this serve you well !druitre wrote:thanks Julca, this one saved my ass today
- Jasper
And coincidence, I have used it again this morning.
julca
Re: Curve To Ribbon
I am glad that this is usefulRoN43 wrote:Thanks!!
