syflex wind controllers
hidalgo
Post by hidalgo » 20 Jan 2014, 19:37
Hello guys,
there is any way to have more control over the syflex wind? i am trying to have a petal to gently float from a point to another doing a "sort" of leaf path, but the wind controller its way to imprecise to rely only on that...any suggestions?
Thank you
Re: syflex wind controllers
Post by EricTRocks » 20 Jan 2014, 21:25
Animate by hand. If you need exact landing position and animation path that isn't unpredictable it's your best shot. Simulation is not that controllable.
Eric Thivierge
Post by Daniel Brassard » 20 Jan 2014, 21:44
Can the leaf be constraint toward a goal?
Thinking like a flocking effect. :-?
hidalgo
Post by hidalgo » 21 Jan 2014, 07:41
@EricTRocks yeah i had initially, but i was after a more natural look
@Daniel Brassard as far as i know a dynamic or simulated objects (the petal) can't be constraint to anything, maybe i am wrong..
caledonian_tartan
Post by caledonian_tartan » 21 Jan 2014, 08:30
...simulated objects (the petal) can't be constraint to anything...
you could linear interpolate the simulated position and rotation with the desired end position in post simulation stack.
may look unnatural. may also work.
SI 2015 @ WIN7-64
Post by Bullit » 21 Jan 2014, 15:59
You could use leaf compound and a flow along curve compound then you give the final positions.
Make an emitter point cloud and final positions point cloud
Since there are same number of leafs as final positions you can use a switch node too to get the orientation from the final position point cloud.
