peel effect in softimage ice tutorial
nikaragua86
Post by nikaragua86 » 16 Jan 2014, 01:08
scene is here
https://db.tt/imC1x0cR
gustavoeb
Skype: gustavoboehs
Re: peel effect in softimage ice tutorial
Post by gustavoeb » 16 Jan 2014, 01:17
an error it says... maybe it is not fully processed yet.
Anyways you are a machine nika! I am still waiting for those videos on the fluid thingy, ever since I implemented a diffusion algorithim and couldnt figure out how to go from there to advecting motion.
Gustavo Eggert Boehs
Post by Bullit » 16 Jan 2014, 05:49
This seems to not be integrable(is this a word?) with Syflex or am i mistaken?
This the best peel effect with cloth sensation i saw recently, still it is not perfect, the pattern it makes doesn't look good.
nikaragua86
Post by nikaragua86 » 16 Jan 2014, 22:18
ahahaha ))) a machine?
like this ?
or this ?
ahahaha ))) believe or not - tha machine freezed the tip of the nose yesterday - so my nos is rotting now ))))
i guess i can consider myself as strogg in this matter
nikaragua86
Post by nikaragua86 » 16 Jan 2014, 22:23
aaaand it didn`t worked because i loaded the stuff into vimeo, posted everywhere, how cool am i and went to better world ))))
don`t worry my friend - i`ll share all the fluid stuff and more - i`m not like him ahahahaha )))) or do i ?
nikaragua86
Post by nikaragua86 » 16 Jan 2014, 22:29
i dont see any reason why it cant be crossbreeded with syflex.
in realtime they could possibly kill each other(i dont know) - but who restricts to use cashes?
as Oliver suggested
https://www.si-community.com/forum/v ... =41&t=4774
aaah, you surely know about it )))))
hmmm... the best peel effect you say....hmmm SOUNDS LIKE A CHALLENGE !!!!!!!!!!
olivier jeannel
Post by olivier jeannel » 22 Jan 2014, 07:28
owei
Post by owei » 22 Jan 2014, 07:59
@Olivier
Look great Olivier..!!!!
@nikaragua
..I thought of the verlet solution as I did my hull destruction test...does is do selfcollisions??
cheers,
oli
nikaragua86
Post by nikaragua86 » 22 Jan 2014, 11:20
emm...selfcollisions? i don`t know, man, you`ve found the right one to ask - i`ve touched this verlet
stuff for the first time )))) ahahaha - i`m surprized as hell that this stuff actually worked - it`s olivier magic - whatever he touches - it works )))
olivier jeannel
Post by olivier jeannel » 22 Jan 2014, 11:44
No self collision as far as I could find. But it does colide with other object, you have to iterate (repeat node) a lot.
Makes me thinks I haven't tried the subframe Simulation Setting. Maybe it helps, or maybe results will be completly different....
