Was looking for a way to get envelope's weights with radial falloff and sometimes not centered on the deformer. ICE was the solution.
Compound Attached.
The group ID on the different groups must be the same for each sub-hierarchy, otherwise there will be a mismatch between the EnvelopeWeightsPerDeformer and correct weight/deformer pair.
pb_EnvelopeByRadius
Mirror FaceRobot Rig
This script mirrors any selected FaceRobot control. The initialization string for
the lookup table used in the script was built using the second script.
local backup: MirrorPose_Apply_02.py MirrorPoseBuildingLibrary_02.py (lookup building script)
author site: http://probiner.xyz / author site: http://probiner.xyz / author @ vimeo / si-community thread
pb_EnvelopeByDistance Creates a flexible envelope based on the points' distances to nulls with control over
falloff/shape/radius for each null. A group or groups are required and the group ID order must match the Deformers ID
order. [..] An update on pb_EnvelopeByRadius since I was feeling the need for more options per
null. Also one to use with single Weights. Compounds and script attached. The script
can be very slow to run (no idea why) and should be applied without the compound inputs
and outputs being connected.
Video demo for the current update as well as for the initial release.
local backup: pb_EnvelopeByDistance.xsicompound EnvelopeCPsets_1.0.pys (init script)
pb_WeightByDistance
A simple version of the pb_EnvelopeByDistance script above outputting to a single
weightmap instead of to an envelope map.
local backup: pb_CopiesOnTarget.xsicompound
probiner
pb_EnvelopeByRadius
Re: pb_EnvelopeByRadius
Thank you for sharing. It's good to have different algorithms for doing the initial weighting.
