Slice or cut
ajhorvath
Slice or cut
Hello,
How would I slice or cut a geometry inXSI with precise angle control(by degree)
I want my geometry cut at 32.5 degree.How can I do this?
I don,t see any numeric angle options in slice or knife.
And I can't fine a cut geometry option.
Please help!
Please help!
Re: Slice or cut
edit: after deleting my original suggestion using booleans, I looked at the User's Guide some more and found that you can define a custom cutting plane for slicing, which you should be able to rotate precisely (i.e. numerically)
XSIDocs: Polygon Modeling > Modeling Polygons & Polygon Meshes > Knifing and Slicing Polygons > Slicing Options > Specifying the Cutting Plane
craft
Re: Slice or cut
Tiago Beijoco
http://www.craft.host56.com
Re: Slice or cut
I'm not sure, where you want me to move this thread, craft.
The imaginary "things even MAX does better" forum or
the just as imaginary "things that should be included in SI before 2018 (but probably never will)" forum!
BTW: have you tried the wonderful "add edge tool"?
(mind you: I have never worked with MAX, so I don't really know what I'm talking about...
ajhorvath
Re: Slice or cut
Thanks for the help.
It's not very simple but it does work.
I wish XSI had spline tools Like Max.
Re: Slice or cut
Yeah 3ds max cut has this nice featurecraft wrote:
that leads to my frustration at trying to figure out a procedure to emulate the cut tool from 3ds max on xsi, that's preety much like the cut in xsi but runs across multiple poligons with a couple of clicks, figuring out the best path. any bright ideas? wanna move the thread to the apropriate section hirazi? ;)
on other hand Max cut is fucked up since 3d studio max 1.0 with numerous bugs that applies to all max raycast tools. inserting new vertexes on another vertexes. inserting vertexes not where you clicked. inserting vertexes on other side of mesh. etc...
Re: Slice or cut
If you want precision in modelling, I can recommend NURbs and Rhino 3d.ajhorvath wrote:Thanks for the help.
And yes xsi curve tools are simply awful. but that was said 1000 times before
ajhorvath
Re: Slice or cut
The truth is that I really would love to use just one software for everything.
I am trying to figure out what that software is.
I hope its XSI,I really like the look and feel of it.
ajhorvath
Re: Slice or cut
I started with Lightwave and Maya after then Max and now XSI.
So far Max is the best and very fast Modeling soft for me but XSI is coming up.
craft
Re: Slice or cut
hahahah i'd say "A) he imaginary things even MAX does better"Hirazi Blue wrote:I'm not sure, where you want me to move this thread, craft.
(mind you: I have never worked with MAX, so I don't really know what I'm talking about...)
naw really, how about programming? that's what i had in mind but now it's maybe better start a new topic.
add edge tool: imagine you got to cut a line through 80 polygons not in a loop, and you don't want it to be a straight cut. max's approach to edge cutting does it in two clicks. As Origin stated max's cut is, as the whole app, messed up big time though. If only i could find a way to mess up XSI without performing a decent cut through many edges with the power of my will....
Tiago Beijoco
Re: Slice or cut
How about "split edges (with split control)", which seems to be able to take all selected edges into account and only split these (even around corners)? The ordinary "split edge" only seems to split edges along parallel edges, while the "...with split control" tool does things slightly "better"... ;)
craft
Re: Slice or cut
Like modo. not eactly what i wanted but it works very fine.
Tiago Beijoco
