Hey All,
I'm playing around with creating self installing plugins, and just had a questions as to why it doesn't like spaces?
It seems most scripts, and editors will convert tabs to spaces for you. Just like the preference in the script editor (which is default?). from what I've read, this helps keep formatting when copy and pasting code between various sources/editors.
So why is it that self installing plugins want tabs instead of spaces?
self installing plugins - insert spaces instead of tabs
missingkey
Re: self installing plugins - insert spaces instead of tabs
It's the code that generates the plugins. The Custom Plugin wizard uses tabs, not spaces.
C:\Program Files\Autodesk\Softimage 2014 SP2\Addons\sdkui\Application\Plugins\SDKScriptGenerator.js
missingkey
good enough for me!
Thanks Steve
Thanks Steve
Easy tip to swap them for spaces:
- Change scripting preferences to use spaces instead of tabs.
- Select all code in script editor
- Hit Tab
- While having all text still selected, hit shift+tab
