Cached ice particle attribute in shader tree problem
jerry7
Post by jerry7 » 23 Dec 2013, 12:10
hi, i render cached ice particle. i use ice color attribute in shader tree and it worked in normal simulation particle. But it can't worked with Cached ice particle.
How to solved this problem?
thanks!
Pooby
Re: Cached ice particle attribute in shader tree problem
Post by Pooby » 23 Dec 2013, 12:45
did you cache the attribute?
jerry7
Post by jerry7 » 25 Dec 2013, 14:02
hi, thanks for reply. i'v cached the attribute.
the problem is i use instance shape with shader that use ice attr. I found that if assign the material to point cloud, the instance shape work well in cache mode. If i assign material only to instance object , ice attribute can't be read.
Post by NNois » 27 Dec 2013, 00:31
hi,
maybe i misunderstood but i think you need to force the evaluation of the attribute
read "beware ice optimization" here http://download.autodesk.com/global/doc ... 896F3-0020
in breif you can use this attribute in your ice tree, or displaying it when you are caching...
