http://www.wisdom.weizmann.ac.il/~ylipman/pmvc/pmvc.htm
this workflow is temporary removed:
"To use it, just conect the initPMVC compound in the modeling region, and the PMVC one in the animation region, both on the deformed object.
The cage must be triangulated! .. but once your happy with the deformation the initPMVC compound may be frozen , and then cage can be quadrangulated.
The only limitation is that all the point of the deformee must be inside the cage."
Edit: updated with the script version for the coordinates generation. I've also package everything in a command in the deformation menu.
For this version, the cage don't need to be triangulated
Also you have to freeze the deformation if you want edit the cage as you cant overwrite an ICE attribute that is in use
Cheers!
this
