Hy,
How can I create a material blending two different shaders, like the Blend shader, in 3D Max?
Thanks,
Blend shader
Leandro Oliveira
Re: Blend shader
Use a mix2color node??
Leandro Oliveira
Re: Blend shader
Thanks, Rork.
But, with this node, I can use two Illuminations shader at same material, like Phong and Mia Material?
Re: Blend shader
F1??
But seriously, why not? Just try and see what's going on when mixing multiple materials ;)
there's even a mix8colors, and you can always daisy chain them if necessary.
Deracus
Re: Blend shader
Just to make things clear...a little example...
it works exactly like in max...has just another name...
Leandro Oliveira
Re: Blend shader
Deracus,
Thanks for the demonstration.
Leandro Oliveira
Re: Blend shader
Thank you, guys!
It worked Perfectly.
