Voxels. First in axis inside a volume?
Post by Bullit » 06 Dec 2013, 23:05
There are some Voxel ICE addons around but all i have found have not the capability to just to have only the first voxels that are seen by the camera. What should be the best approach to this situation? would first valid node be something to apply for this?
sant0s
Re: Voxels. First in axis inside a volume?
Post by sant0s » 07 Dec 2013, 20:35
sry, maybe I do not understand you correctly - but you want that only the voxels/particles get build, that your camera on the first frame is looking at?
if so, like that?
Post by Bullit » 08 Dec 2013, 00:46
Correct, wonderful. Is that a current ice node? I don't remember it.
sant0s
Post by sant0s » 08 Dec 2013, 08:37
Bullit wrote:Correct, wonderful. Is that a current ice node? I don't remember it.
jop, it is. :)
Post by Bullit » 09 Dec 2013, 00:09
Ok.Thanks.
Post by Bullit » 12 Dec 2013, 23:52
It seems it is not quite what i want. I need only the first voxels not those that are behind the first ones. I need a voxel wall with only one depth level.
Pooby
Post by Pooby » 13 Dec 2013, 08:21
If you are emitting them from a mesh, you can test distance to surface to delete the inner particles.
To base the deletion on the cameras view would be more complex, but doable, I'm sure.
sant0s
Post by sant0s » 13 Dec 2013, 10:09
you could directly work with even point distribution on surface and do the camera stuff on that?.
Pooby
Post by Pooby » 13 Dec 2013, 11:20
That would produce quite a different effect though
sant0s
Post by sant0s » 13 Dec 2013, 14:01
yea, you are right - looks like messed voxels :D
Post by Bullit » 13 Dec 2013, 14:42
Yes. I am thinking also to trying another solution: using only the frontal polygons and delete remaining mesh.
Since i will not be rotating the mesh or moving the camera any voxel is a performance hit.
Problem is that several voxel compounds around are only for enclosed mesh.
Post by NNois » 13 Dec 2013, 20:07
hi,
emTools by eric mootz, permits you to do just that, just look at his lasts videos there is a part when he emit voxels, then use a mode to delete the inner particles but keeping the one on surface, couple that to an incidence by the camera and you are good
Post by Bullit » 20 Dec 2013, 19:45
Thanks, had finally time to look at this. Unfortunately doesn't work with emtools as is.
I don't want to delete the inner particles i want to delete all particles except the first in a certain axis, also anotehr node that might have helped the equal distribution on surface does not work well in objects that have planar faces planar.
