Hello again
Winter is coming! so be prepared and create Ski Lifts!!!
This Compound doesn't need simulation. although the cabins are moving, it's in an unsimulated IceTree. No black magic involved, or at least not too much ;)
Just create a Curve on your Terrain and Connect Instances if needed.
here you can download the scene (SI2014)
reports are very welcome
cheers
EDIT: you need to have mt_strandfittng (by helge mathee) installed!
EDIT: the scene file has been updated, including some fixes
Ski Lift
Ski Lift Hello again Winter is coming! so be prepared and create Ski Lifts!!! This Compound
No black magic involved, or at least not too much ;) Just create a Curve on your Terrain
and Connect Instances if needed. [..] reports are very welcome.
Requirement: »mt_strandfitting« by Helge Mathee (included in »mt_strandNodes« directly below).
local backup: skilift6a.scn
author link: n/a / si-community thread
nikaragua86
Re: Ski Lift
Ski Lift? Great !!! Could you please make a snow? Aaaah, forget it, its great like this - NEVER ENOUGH HARDCORE BRUTALITY!!!!
Could you give some instructions on installing the mt_strandfittng ?
But even without them looks awesome !!!
caledonian_tartan
Re: Ski Lift
want snow? here. someone has already made something interesting.
otherwise you got to wait quite a bit to be able to ski down that little hill ;)
regarding the mt_strandfitting: you only need to put the folder in your workgroup or user directorys addon path.
C:\Users\dude\Autodesk\Softimage_2014_SP1\Addons
btw, there are some issues using ski lift compound when there are not enough cabins. i don't have no time or interest to fix it so far. just use many cabins to make it work properly. sorry for that.
SI 2015 @ WIN7-64
nikaragua86
Re: Ski Lift
thanks a lot, its working fine !!!
