what's up with that screen capture function? No matter what codec I choose, only the first frame gets rendered. I definitely have the frame sequence set right.
Any ideas?
Eugen
Screen capture not working?
Eugen
SamHowell
Re: Screen capture not working?
Are you capturing a Quicktime? Try using Photo - JPEG for your codec. Also check you don't have quick time open while you are capturing.
Eugen
Hi, thanks!
I tried AVI, jpg sequence... didn't help.
SamHowell
You could try a hardware render. It's almost as quick as doing a capture.
Eugen
... of course! Thanks!!
;p
;p
is to capturing or quitting on the first frame? if it quits immediately, it's a sharing violation (close the videoplayer) or a problem writing to the path
