Nika is helping me with ICE and we're at a point where we'd need ICE to know the files dimensions of images in an image sequence of different image dimensions. Is there a way to make the dimensions of each image readable by ICE ?
Regards,
Frank
ICE to read file dimensions
Re: ICE to read file dimensions
you can browse to the image source but nodes turn red when you access the dimension properties. did you tried it ? plus accessing a particular time on your clip seems tricky and not possible.
can you write an array with you images size, how many images did you have ?
keep in mind that ice can read texture maps so you can for example write 2 small pixel in a corner representing the scalar x or y value.
In my opinion you need to process your images in a compositing pakage to maintain the ratio if it's what you are after...
Letterbox
make sphere
sphere.Texture_Map.noIcon_pic.noIcon_pic.xres
sphere.Texture_Map.noIcon_pic.noIcon_pic.yres
for specific images or Sources.(imagename).XRes for generalization case.
I'll assume you have all the texture maps connected. Then use my vimeos to further expand the possibilities.
https://vimeo.com/27055572
https://vimeo.com/27069071
https://vimeo.com/27070170
to test
connect either case above to the rate of particles in an emit from geometry on the sphere(total particles). and see what number it generates on frame 2 from a show value which connects the rate.
to test
nikaragua86
thanks, friends, we`ll try all possibilities
Frank1000
- Skype: the2he
interesting link to related topic https://www.si-community.com/forum/v ... =27&t=1975
