Stats in Render Output
Frank1000
Skype: the2he
Post by Frank1000 » 22 Nov 2013, 16:45
Hi, where do i turn on the stats to be output inside the rendered images of the hardware render ? Same way as i have it in the viewport turned on in the visibility options ?
Re: Stats in Render Output
Post by Hirazi Blue » 22 Nov 2013, 16:55
The necessary settings (including the enable-switch) can be found under "Slate" in the "Render Pass Property Editor"..
Frank1000
Skype: the2he
Post by Frank1000 » 22 Nov 2013, 17:26
thank you :-)
