What is the best things to know about NVIDIA panel to have best performance/quality with Softimage 2010 ?
The first I do is to remove Vertical Synch ...
Phil
GTX285 best config in NVIDIA Panel
Re: GTX285 best config in NVIDIA Panel
The other setting that springs to mind:
The Anti-Aliasing setting should be set to "Application Controlled".
Thanks HIRAZI,
But its seems I loose some fps in Softimage with the benchmark I found in XSIBase (I let it to disable).
The worse thing is GTX285 - 1Go is not far better than my old GT8800 - 320 Mo moded in Fx4600 with rivatuner 2.24.
GTX285 is only about 10-15% better ...
Phil
Phil
