ICE deformers...
thorsnuts
ICE deformers...
Hello...
I would like to apply a Turbulize mesh on a certain part of an object using a weight map, but I cant find a way to use the map.
Is there a way? Is there a work around? Is there an alternative?
thanks for the time,
Pooby
Re: ICE deformers...
multiply the vectors by the map (multiply by scalar)
thorsnuts
Thank you sir...
May I ask for a bit more direction as I'm not that professional with ICE.
Would I go into the Turbulize Mesh node... then into the Turbulize Around Value node... and have that Multiple by Scalar run through the map?
thank you very much!
sant0s
one way
Moderator edit: original image replaced due to its "questionable" content ;) - HB
thorsnuts
oh thanks santos... hahahha what is that... a rocket ship!
Now, this can be used to modify the Turbulize Mesh node?
sant0s
hehe, yea , rocket ship
exactly, if you click on that little "e" while hovering over the Turbulize Mesh, you will see, that my example is actually the same thing.
forton
It's a variation on the turbulize mesh compound, with a weightmap.
Now I keep wondering what the -non censored- screenshot looked like
Cheers, Wim
Cheers, Wim
thorsnuts
thank you... seems to work, but.... it flattens out the part of mesh I dont want effected by the Turbulize.
What would I do to counter act that?
thanks again,
thanks again,
sant0s
don get what you mean exactly...
actually the mesh stays and only where the weightmap is painted, will be randomized mesh.
I did set x and z to zero, so only y is affected.
but, tell me what you mean, maybe I can help ^^
thorsnuts
Sure thank you....
When I apply your method, this is what happens to the part I don't want effected by the Turbulize.
How would I counter act this?
thank you very much.
sant0s
thats again just one way, just play around with the nodes, plug them in different ports, ect.
oh and smooth the weights with the smoother to avoid bad seams.
thorsnuts
Awesome dude... thank a lot. works as expected!!
But what is that .380 node you plugged into the factor of the multiply by scalar?
thanks I really appreciate your time.
sant0s
you can change the overall scale there. I did insert that "scalar" node just to show on screen what value the "multiply by scalar" node has.
and your welcome
and your welcome
