greetings to you!
i have a scene with plenty objects that have two UV sets.
one for input (to place the textures onto the faces)
one for output (to bake onto)
when i export the scene as obj for later realtime use, i want the export UV coords with the objects.
what i get at the moment, is sometimes the input uv, sometimes the bake uv.
is there a way to choose which uv to be exported ?
like making one uv the higher priority or default or something.
would be awesome.
cheers!
choosing uv for obj export
myara
Re: choosing uv for obj export
deleting one before exporting would be the easiest way to do it.
M.Yara
gaboraa
Image node in render tree gives you an option for specifying which UV to be used for rendering. Maybe this feature is considered when exporting
Superpositivo
I always noticed that the exported Obj uses always the first UV at the top of the object's stack.
