knife tool
rpmaguire
Skype: eyekeystudio
knife tool
Post by rpmaguire » 13 Nov 2013, 21:00
Is there a way to use the knife tool to make an object into to 2 objects?
Thanks,
RYan
Falam
Re: knife tool
Post by Falam » 13 Nov 2013, 21:12
What you want is the split edge tool, then you can break up one object into multiple objects, which is the direction you want for dynamics :)
rpmaguire
Skype: eyekeystudio
Re: knife tool
Post by rpmaguire » 13 Nov 2013, 21:29
Say I have a complex piece of geometry.
And I slice this geometry on an angle, I want to delete one half of it...And since It is an angled Cut I can't select the half in an orthographic view , But I have to go in and painstakingly select polygon by polygon along the knife cut.
If The cut would make the object Into two objects , Then I could just delete one half.
Hope this makes sense..
I will try to post a pic
rpmaguire
Skype: eyekeystudio
Re: knife tool
Post by rpmaguire » 13 Nov 2013, 21:37
Here is what I mean
rpmaguire
Skype: eyekeystudio
Re: knife tool
Post by rpmaguire » 13 Nov 2013, 21:48
All of the selection modes seem quite sloppy and slow for something like this...
If softimage had a polygonal lasso mode it might be better... But there has to be a way to cut an object into 2 with the knife tool ?
Re: knife tool
Post by Daniel Brassard » 13 Nov 2013, 21:50
http://download.autodesk.com/global/doc ... lygons.htm
You can also use the cutting plane.
rpmaguire
Skype: eyekeystudio
Re: knife tool
Post by rpmaguire » 13 Nov 2013, 21:59
Perfect!
Thank you daniel!!!
Don't know how I missed that, The slice property dosen't automatically come up for the knife tool.
Went into the exlporer and found it.
Problem solved
Thanks Again
fabilabo
Re: knife tool
Post by fabilabo » 14 Nov 2013, 10:14
Or simply a difference boolean op ? create a cut box and substract it
