Hello !
I want share with you my last ICE Compound "Select in Array until Max Sum".
It can be used to randomly get many objects with different shape size, one after other.
You can see below one way to use it :
I hope you like it !
Cheers.
Select in Array until Max Sum This compound uses a repeat loop to select random or sequential entries of an input
array until their cumulative sum reaches a given threshold. For the sequential selection
it offers the options to loop/clamp/bounce through the array with a user defined pivot
index. Related: »Cumulative Array Sum« compound by Julian Johnson. Go
here for an introduction video.
local backup: Select in Array until Max Sum.xsicompound
julca
caledonian_tartan
Re: Select in Array until Max Sum
uhh, procedural bookshelf is coming!
thanks for the compound
SI 2015 @ WIN7-64
